Spohn Sway Bars are in!!
No criticism intended as they look like quality parts but is that front bar any larger diameter than a stock GN bar?
There is a larger (beefier) bar for the rear available too I think but without knowing the diameter of your new bar I can't be certain.
Still, they are nice pieces 🙂
What do they cost?
rear is 23mm iirc and the front is 34mm. I am aware that a GN sway is available but, these were $329 with all hardware and bushings and end links(polyurethane). I just wanted a new set that was bigger than stock and I dont have a rear sway bar installed now(that way when I purchased the car).
Not a bad price. If you didn't have a rear bar before then yeah...anything will be a nice improvement 🙂
Some think the larger bar for the rears (35mm) is too large but it helped my GN in the curves a lot.
I also have poly end links and mounts up front and you will love that 🙂
Is your regal a t-top?
Hey now....T-tops are nice 🙂
If you don't already have them there are 3 bars that go from the front to the engine cradle and form a triangle to tighten the front up too.
Not sure how much they would do on a solid-roof car but they are available.
You doing anything to the control arms?
Did the rear bar come with LCA inserts where the bolts go through?
I have tubular upper and lower rear control arms in route as we speak with poly bushings. I havent decided on the front control arms yet. And the rear sway bar didnt come with the inserts that you mentioned
No problem on the inserts if you have tubular LCA's, they don't require them.
Take lots of picts 🙂
I love putting suspensions together.
will do. Im going to order the tires Friday so when my wheels and tires get in, then its off to the garage for a few hours to swap everything out and then to the alignment rack.
not a bad price, spoohn makes great stuff, i have their front lower tubular control arms.
but for sway bars i am running
stock 36mm F-body sway bar $89.00 new from dealer
stock poly endlinks& sway bar bushings $30 from summit
1 3/8" rear sway bar and grade 8 bolts $ 129.00 from ATR when they were around.
sometimes its good to shop around
all said and done $248.00
