Clanceman427 said:Hi, from my experience, and a friends Chevelle, the Moroso trick front springs do drop the front end. I put the Moroso 47205 front coils in my car, Moroso says they are for G body, 1660-1720lb front end weight range, and 242 lbs/in.
I put these springs in before I built the car, and when I finally weighed the front end with me in it in full race-ready trim after teching-in, the car was actually 1920lbs in the front. My car sits lower in the front, and also has an abnormality, the pass. side has about 5/8" clearance between the lower bump stop and the frame, whereas my driver's side is basically sitting on the bump stop/ zero clearance between bump stop and frame. I'm wondering why this discrepancy, and looking at the frame and suspension nothing seems bent or damaged. I recall when I installed them that I was dilligent on clocking the spring relative to the lower spring pocket's drain hole(s) correctly. I wonder if the isolator got misplaced upon installation? But this wouldn't attribute 5/8" of difference, right? I have to investigate more, I'll never know until I pull them and check the rate so that I know both are the same spring.
I highly recommend weighing your front end in race/street ready trim before ordering any springs.
Kevin
