DAMN im always there and i cant never find engines and trans... guess i better getthe 305 up and running so i can b in there DAILY!!!!! i wanna run a ls motor and 5 or 6 speed... my car came with a 3 speed from the factory
Ya i found another ls1 i just couldnt find help to take it out so when i went there early sat couple of guys beat me to it DAM!!
also found a couple 8.5 rear ends for 60 bucks
Nice ride, can't believe you found that engine at the junkyard! Me and my bro Kuruption can never find any LS engines up there. Best believe I'll be up there more often looking for one now.... I'm up north off of 83rd and Union Hills...
my boy found his ls2 in the yard... $1000 motor and trans low mile, they thought it was seized took a spark plug out and freed it up, motor is fine... started and runs, good compression, you dont find those often, some people have all the luck
Junk yard treasures are the best. I got my 500 Caddy for the cost of come pick it up. I like your car. Home built like my 442. Did you use a GN gas tank & in-tank pump? What engine the 5.3? 3.42 gear? What kind of power do you expect it to make? Plan to make some test n tune passes to see what she does in the quarter? Fuel mileage should good to.
I like the rim sizes. (and looks) I plan to run them on my next gbody project. I plan to run 245/45/18s & 275/45/18 drag radials. What brakes do you run? Any input on suspension brakes tires for use with this wheel size? I hope you can in time put up more pics and more info with those pics. I like the (relative) factory understated appearence, flat hood, no giant race tach etc.
