All you are doing is taking it apart and rebuilding with the correct parts. If it is original it can probably stand a new "rag" anyway. I had the same problem. My '83 Bonnewagon came with the "O" ring hose steering box but my '79 Pontiac 301 used the old flare hoses. EDIT: So I tried swapping the later Buick 231 power steering pump onto the '79 301 and it was a no-go. Much easier to swap an old Firebird steering box on and change the Pitman arm to a "G" body unit. Then I just rebuilt the rag joint to work with the Firebird box and the Bonnevile shaft.mash the two together
![s-l225.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=https%3A%2F%2Fi.ebayimg.com%2Fthumbs%2Fimages%2Fg%2FziAAAOSw0Lha7LJi%2Fs-l225.jpg&hash=f4928ede49313c1cad8bc07e2c5f57e6)
