My 1978 Cutlass Supreme is low miles (< 30,000). The steering feels good, but is off center. It doesn't look like any of the crusty tie rod ends are bent. I have a goal to replace every dry-rotted bushing and booted joint, so I've put this part list with Moog parts. It's coming to $175 on Amazon and $167 on Rock Auto, which is $100 less than the "proforged" kit with similar parts (nicer adjusting sleeve).
Does this look like a good kit? What is the likely culprit with the steering wheel off by 15-degrees?
It looks like that Pitman arm isn't a thing that wears-out (has no rubber and is splined). I'm fairly certain I can use the crusty OEM Pitman arm without issue.
Notice the shocks... good, but not best. May eventually flip this car.
