EL CAMINO Steering wheel nut
KCP
KCP
145
239
Bavaria, Germany
#1
Dumb question maybe. My 85 El Camino is missing the steering wheel nut. What size nut do I have to look for?
pontiacgp
pontiacgp
Canadian Prime Minister
Mar 31, 2006
24,126
9,318
Kitchener, Ontario
#2
Those are thin nuts, I guess you don't have wrecking yards with GM cars around you, maybe someone here has one they could ship to you. I don't think that thread is metric and they are SAE 9/16" fine thread
KCP
KCP
145
239
Bavaria, Germany
#3
Thanks a lot! Non-metric bolts and nuts can be had here, I just need to know what to look for as they are special order parts in metric land.
pontiacgp
pontiacgp
Mar 31, 2006
24,126
9,318
Kitchener, Ontario
#4
I could be wrong about the thread though so I hope others will pop on to confirm or correct
69hurstolds
69hurstolds
976
1,149
Figuring 85 Elky is the same as 85 Olds Cutlass, the nut is an M14 x 1.5 if that helps any. Only part numbers I've found for that is 11609658 and 26056108.
http://rover.ebay.com/rover/1/711-5...0001&campid=5335822911&icep_item=322785595308
The retainer that clips on the end of the shaft is part number 419454. You don't really HAVE to have this, but it should keep the nut from coming all the way off driving down the road. :)
http://rover.ebay.com/rover/1/711-5...0001&campid=5335822911&icep_item=401089320810
Not sure if they'd ship to Germany, though.
HTH.
KCP
KCP
145
239
Bavaria, Germany
#6
M14x1.5 would be perfect. I have this size in my shop to check. With the GM part number I can get it at any Opel dealer here in Germany. This part# has a direct Opel part# equivalent.
69hurstolds
69hurstolds
976
1,149
Just to clarify, simply because the part number was found doesn't necessarily mean GM still has them in their warehouse. They may have a superseded part number meaning there's another part that will work and is GM approved to work. May not look exactly the same, but fit and function will do the trick.
Part numbers are always a good place to start, however. Good luck.
69hurstolds
69hurstolds
976
1,149
21044092 and 19151769 are other similar part numbers to try along with those others. Again, good luck. I'm sure you'll find something.
