Sticky steering wheel
JD1964
374
506
Is there a way to prevent the steering wheel form getting that sticky condition? Feels really tacky after it sits a while.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,177
9,779
Gainesville, Fl
Perhaps look into a nice leather sew on steering wheel cover. Although your wheel appears to be in pretty nice shape despite the gooey slime that these wheels emit.
abbey castro
1,048
1,318
Harker Hts TX
99% Alcohol will dissolve/remove the sticky substance. I use it on mine and it works. Try it on a small part to see if it will work for you.
Reactions: 5 users
SS_Malibu
1,172
2,052
Mesa, AZ
Years ago I used to have a 78 Malibu with the same color interior and both the wheel and horn also emitted a sticky goo. I ended up changing out the wheel because I couldn't get it to stop.
CopperNick
3,357
3,018
Canada
During the Covid madness, excessive use of the high test version of Purell was a fact of work life. found that the 70%+ alcohol variant made a great steering wheel cleaner. Slather it on your hands and apply the excess to the wheel and then wipe it off with a paper towel. In the fuglies, it often took a serious number of repetitions to get the wheels clean because most of the regular drivers had never paid attention to keeping the cabins clean, never mind giving the units a regular bath. I still get "Generous" when applying the stuff and then slathering it on the unit's steering wheel. S*** that gets moved and handled around iby us n my city is anything but clean and sterile; more like germ and virus central and the average sheeple is dumb to the point of permanent stupidity about public hygiene.
The high test alcohol can be acquired at any local drug store or pharmacy. Up here you might have to ask the pharmacist because certain elements continually try to subsitute it for the real thing with lethal consequences. It also makes great cleaner for purging brake lines.
Reactions: 4 users
pagrunt
9,168
15,350
Elderton, Pa
One of the joys of the steering wheels in our cars. Either they are goo producers or just shrink & crack.
Reactions: 5 users
JD1964
374
506
The true car owner is my son. He’s the owner and I’m the mechanic. I had approached him on the idea of an aftermarket wheel and he said no. He likes the stock wheel.
Longroof79
Oct 14, 2008
12,177
9,779
Gainesville, Fl
I also had the same color interior and wheel and couldn't get the gooey stuff to stop. I still have the old wheel hanging up in my garage after replacing it.
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
I had the cracked, hard plastic variety. I wrapped my wheel with a cheap imported EBay 'leather' wrapper. It stretched like a goatskin glove, but didn't match the wheel color. I replaced it with a blue Wheelskin cover, same baseball stitch. MUCH better quality and the color was a reasonable match.
On another car, I was able to find a Cherokee wheel from a Forum member that really matched the (sticky) stock Malibu wheel color, but will never get sticky, not made of molded vinyl.
If you choose the first option, clean the hell out of it with 90% isopropyl, then use BOTH the EBay wrapper and a red Wheelskins cover. You'll end up with a thicker, padded wheel like what I ended up from a Cherokee. For 1/3 the cost plus your labor.
  • Informative
