Still Having Brake Issues
I always have a nice clean piece of wood for under the pedal. My "helpers" are usually not real drivers but will help. Having them push the pedal to the block and tell me "down" and they hold it there. then I close the bleeder and when closed say "up". and they let the pedal return up and say "up" when it gets there, and then I open the bleeder and say "down" and repeat the process until I am happy with that wheel. Over stroking the mc will definitely cause you a lot of problems with getting air into the system. Way better to use shorter strokes and have to do it many more times than to try and do the pedal three or four times and call it good.
You said your self you started with empty lines so that will take a lot of fluid. Then you have the fluid that is used up with the bleed process. And making sure the reservoir stays full, or you get to start all over again bleeding the mc.
I can't see how the booster is causing the pedal to have slack but I'm no expert. I just think you aren't being patient or during the bleed air is being reintroduced some how.
Give it a few days off and work on something else if this is frustrating you that much. A clear head and plan of attack is way better than getting upset and throwing stuff.
Reactions: mikester
also remember stock gbody brakes are shitty at best, so maybe your brake are good but you didn't expect them to be as shitty, make sure your rear shoes are just touching the drum, next go buy some fish tank air line and air line check valves there cheap as hell but you need to replace it for each brake, bleed them until no bubbles are seen the check valves will allow you to bleed them by yourself and you'll have plenty of hose to route the bottle in a convenient place for you to see. remember to hang it higher than the bleed screw.
Yup. Issues fixed. Pedal is nice and firm. On to the next fix. The starter wires are just a little long since I switched to the mini starter. They also need new terminals. Putting them on tomorrow and shortening the wires at the bulkhead connector.
