stock posi question
gutlesscutlass
10
canada
bikepics.com
if i have stock posi gears in my 86 cutlass 4- door 305 with o/d what gear ratio would they be?
The rear axle ratio will depend on what your car was equipped with from the factory. I would guess a 2.41, but it could be something else. You need to read the SPID codes on the sticker under the trunk lid.
Rear Axle:
GH2-2.29 ratio
GM8-2.56 ratio
GT4-3.73 ratio
GU1-2.41 ratio
GU2-2.73 ratio
GU4-3.08 ratio
GU5-3.23 ratio
G72-2.14 ratio
G80-limited slip differential
G87-8.5in 10 bolt axle
G89-7.5in 10 bolt axle
http://gbodyforum.com/viewtopic.php?t=5155
