If you are going to build a 350 and have all the machine work done, build a 383 (.030) or a 385(.040) you can run a much tamer camshaft and you will be so much happier with the torque. I run a flat tappet now but ran a roller in my last car. Both are relatively small cams but the engines are both torquey as hell. My suggestion is to call Competition Products and ask those guys as they are seasoned vets in the business, they are a Howard's cams distributor and they will help you every step of the way. My last engine was a 385 with brodix IK 200 heads with 1.6 ration rockers and a lunati voodoo cam. It only had 530 lift but the car had instant response and would shred rear tires. And the idle was lumpy. And the entire engine built was about $2700 dollars. I had a friend that helped with the machining which explains the lower cost but parts were economical and all bought through competition products. Just tell them what you expect from the engine and what you will use it for. And if you run a cast crank, be careful with your revs. And I always run synthetic oil. I will use it until they put me in the ground. Use what you want but those are my suggestions. Call those guys, you won't be sorry.Ok, short story is this. Rebuilt 350 (80k) 1970 010 020 4 bolt rebuilt spdpro flattop stock o rods arp bolts. 9 years ago it was done. But they didn't align hone the crank or catch (not care because bought through jegs cheaper than them) 2 counterclockwise turned speedpro pistons by bout half inch. Bored it to .030 for pistons but didnt torq plate it and we agreed to do it and wrote it down.
This year Had a bowtieoverdrives pdqmade lightweight 700r4 2600rpm with lockup lose tcc. (Internal leakage etc so no tcc but fixed it free even shipping)With trans out of way so I decided to fix leaking oil main seal since started leaking 3 yr ago but only 10k miles. Upon teardown I see back thrust bearing is gouged n splitting up under main cap. Copper flakes and burnt black but no wear on main journal. Thrust on crank gouged like bad cheap brake rotors. So wtf, 1 bad thing leads to a discovery of another. What a basket case so I tore it all apart since needs a crank anyhow and found issues on heads n cam lobe.
Had looked over by new machine shop n say the 2 pistons are ok should replace cause not straight n since need crank do a eagle 385 kit n do new 040 pistons.
Debating whether to just get new 350 crank for total of bout 850$ out the door or a eagle cast kit ext balance for 1550 or same eagle kit but it bal forged crank for 1950 parts n labor no tax. Then bleed out more for roller cam and heads. Or buy a new zz4 shortblock for 2500 or new l31 vortec block with heads for 2080 off jegs but sadd dish pistons but new block roller ready. I dont really wamt to use someones rebuilt stuff and have to trust them. Thought blueprint engines being advertised buy internet has some stories on them. I know about doing ls6 springs n gmpp/ comp retainers to get valve clearance without machining guides.
Solid rollers are a pain in the *ss anyhow. If you are running the street, hydraulic always!!!My goal is to be able to use pump gas and make over 400hp on motor if stays a 350 or 383 close to 450hp. Would like to use 87 gas but premium is a price to pay for compression I know. I don't want to lash rockers every year (parked for winter dam u minnesota ) so prefer not a solid roller. And lastly be durable as a factory motor lasting 100k like daily driver duty but able to be beat on on weekends strip street summer cruising . Hardest I ever ran it was 6krpm at Rev limiter bout 130mph side by side in open country against brothers 09 jeep srt8 cherokee. That 6.1 hemi couldn't take me until that speed where he had od and my 700r wouldn't hold od in wot (dunno if I changed that yet)
I have been running solid rollers on the street for over 15 years, there are a lot of misconceptions out there based off of the old solid flat tappets that needed constant adjustment and race solid rollers that need splash lubrication and will fail on the street but now there are pressure feed roller lifters and these are needed when the cam size, spring pressure and RPM range exceed what a hydraulic roller can handle.Solid rollers are a pain in the *ss anyhow. If you are running the street, hydraulic always!!!
