Stroking G-Body Motors
81_El_Homewrecker
170
There goes 30 minutes of my life I’ll never get back...😂
On a serious note, if the goal is to raise compression to get more out of a shitty engine, wouldn’t it be easier to pull the crappy heads off and have them milled down from 76cc to 67cc or something?
8,823
7,775
You can use stock parts, except rods but sbc in an Olds to make a stroker. Because the Olds 350 has thick walls, can go over +.100" oversized, stock sbc 400 pistons or any of the oversizes will work. Now combine aftermarket 6" sbc 2" small journal rods, they never came that length stock. Or get a 6" with 1.88" Honda journal aftermarket rod. Olds made a factory forged steel crank from 64 to 67 in the 330 V8. I have 2, not super hard to find. All small block Olds have a 3.385" stroke, crank needs to be in good shape with standard journals. Now offset grind the 2.125" rod journals to 2" for a 3.5" stroke or the Honda 1.88" journal for a 3.6" stroke. With a 4.185" bore size and 3.6" stroke puts the Olds 350 around 390 ci. The 4.125" and 3.5" stroke, 375 ci. A 4.155" bore and a 3.5" stroke is 380 ci. That is how it was done for years in the Olds community. I have custom 4.390" Venolia pistons on Scat 6" sbc 2" journal sbc rods and a 330 offset ground crank for 424 ci from a 403 block. Technically one aftermarket part in an Olds 350 for a stroker. The same thing though, 50 extra ci with a smaller bore for better cooling and a stronger, lighter aftermarket 4" stroke crank is a no brainer in a performance application.
Gwarren79
711
1,548
Safford, AZ
1,167
2,638
West Virginia
Has anyone placed an order yet?
9,614
12,683
Well he spent a large chunk of time over the past couple years figuring out a way to stroke all Gbody engines and within a week of posting this thread it was narrowed down to just a SBC so by now I am sure reality has set in that the theory doesn't work in the real world and there is no short cut to installing a stroker crank.
Sorry no patent to be had here.
