megaladon6 said:just in case, you do know that the nut is inside the frame? you need to get an open end or box wrench on it and the undo the bolt. you get to it through the opening for the control arm mount. having an air gun really helps here. if you are doing the suspension too, it's MUCH easier with the control arms out.
