the transmission choice is up to you man. The more options you got along with compliments from these guys here will help. Its your wallet on what you choose for your car, either way i looks like its gunna be a bad *ss build. As far as the motor mount pads, Your either gunna have to use a Chevy Motor for those pads or unbolt what you had and find some that will fit your olds. The olds 350 has a wider stance than the chevy 350. No modifications will make a olds motor bolt to chevy pads, I already tryed and failed, :lol: i even welded in tabs to extend the mount to the pad and they wouldnt alllow the engine to clear the hood.
Yes you need the pads in the pic, with those the olds 350 will bolt into the proper location (same size a factory 307) that way there's nothing for you to figure out, everything will line up. You can use the pulleys brackets from a olds 307 the whole accessory setup.
