sulphur smell from exhaust...
83cutlasssedan
239
45
Manitoba, Canada
www.cardomain.com
Noticing a strong sulphur smell from the exhaust after a going for a drive in my Cutlass. I just put in a new intake and a 4bbl carb. Don't really notice the smell at idle only after a drive. I've heard a few different things about what this could be.
1. Bad catalytic converter. It's about 26 years old.
2. exhaust manifold leak.
3. New carb running to rich.
What do you guys think?
The smell is usually caused by the gas. You can try different gas and see if it gets better. Even newer cars have that smell and nothing really can be done about it. There should be no reason to replace the cat if the car is running good.
84dragcutlass said:
sulphur smell would defiatly be a bad convertor
Nope, sorry. Read the emissions section of your Chassis Service Manual. The sulfur smell is from an overly rich mixture.
the sulfur smell is from a non functioning cat. excess fuel in the exhaust is a completely different smell.
however a a rich condition kills cats. first i'd tune the carb, start by checking the plugs to see the running condition. after you do the carb you might want to look at a cheap cat, for the simple fact that the old ones are highly restrictive and it's 26yrs old and at least partially plugged.
just gut the cat and put it back on. prolly wont help emissions but might help with sound/ power. lol . might want to get the carb dialed in to
83cutlasssedan said:
well that would make sense since I just put a 500cfm carb right out of the box on my 231 v6. I should probably buy the calibration kit that comes with different rods and lean it out a little.
you may not need to lean it out...your two primaries are smaller on the 4 barrel than the 2 barrel you just removed so don't go guessing what rods/jets you should be running...and if your going to doing exhaust work then do that first before you check to see if you have to do anything with the carb
