SUP GBODY FAM!!
80/MALIBU/COUPE
108
173
TUCSON AZ
HI EVERY G-BODY !!
SO NICE TO HAVE ANOTHER PROJECT..
PICKED UP THIS 80 MALIBU THE OTHER DAY
SUPER EXCITED ABOUT IT
CANT WAIT TO PLAY AROUND WITH IT
NEED SOME ADVICE
NEEDS SOME PARTS LOL
PLANS INCLUDE A LS 6.0.. 4L80.. BIG BRAKES.. AND CLEAN
TOURING/ X CROSS/ DRAG/ STREET
HOW I FOUND IT
REALLY ROUGH .
A/C & HEAT DELETE KINDA UPSET ABOUT BUT EHHH
"NEWER" 350 LEAKS FROM INTAKE TO OIL PAN AND TIMING COVER TO REAR MAIN
POWER STEERING LEAK ALSO..
SO I TOOK IT HOME
CORNER TRIM GONE
GRILL PEELING
AFTER A GALLON OF SIMPLE GREEN AND PRESSURE WASHER FOUND HUB CAPS IN TRUNK
FIRST AND LAST BURN OUT HAHAHA STARTED DRIPPING REALLY GOOD OUT OF THE REAR MAIN
  • Love
80/MALIBU/COUPE
108
173
TUCSON AZ
Welcome to the forum. Assuming there is no rust you have a great car to begin modifying. You won't regret going with LS power.
THANX !! YEA SO FAR SOLID CAR HAVENT GOT INTO THE GUTS OF IT YET ..
ANY AREAS KNOWN FOR RUST ? IM NEW IDK WHAT TO CALL THIS THING YET .
MALIBU/ EL CAMINO.. A BODY / GBODY
EVEN THE VIN DECODES AS AN UNKNOWN LOL
WAS HOPING TO PUT POWER WINDOWS IN ANY THREADS YOU KNOW OF ?
MalibuDavyou5
365
776
Wyoming
Wow, You got your Malibu in better shape than I did. I wish I could afford an LS swap myself, but for the time being I am in the process of having an SBC 350 put in the 81', Mechanic has to test the Engine I bought first. Welcome to the family and good luck on those parts. Finding them second hand would be cheaper if you can find someone who has them. 🤞
80/MALIBU/COUPE
108
173
TUCSON AZ
THANKS YEA IM HOPING I CAN FIND/MAKE A DECENT INTERIOR FIRST
Doug Chahoy
2,565
2,663
Welcome, nice starting point. Theres enough members on here that remove they’re heat and a/c. You’ll probably get hooked up. I just finished aquireing and painting my 79 Elco interior. As for rust, rear frame rails are always the first, then bottom of doors, body mount area both frame and floor. Rockers, inner and outer.
Doug Chahoy
2,565
2,663
Just consider it a 1980 Malibu G-body
Ribbedroof
4,905
7,013
Wellston, OK
Pretty sure I have an '80 left headlamp bezel (driver quality). It'll be a few days to verify since we've had historic snowfall/cold temps, before i venture out to the shop again.
83StreetMachine
395
819
Central NJ
I have to ask, how much snow is historic in Oklahoma?
I have an '80 grille in great shape, but it has been painted black
O. D. Showtime
3,008
3,537
Regina Sask. Canada
Welcome to the site!
I have corner marker lights and the center dash vent. May be able to help with other parts.
