Hi, guys! I'm in the process of swapping the stock suspension on my 88 Cutlass Supreme Classic to the F42 suspension. I have the big front sway bar, and a smaller rear bar for the rear. The front comes with the mounting brackets and the rear did not. Has anyone done this swap, and if so, what do I need. I looked at the rear and a few other options and I come up with what I think I will need. For the rear, I have after- market control arms, but they are adjustable tubular, and I think I will need to get an extended or adjustable box set. What will need to be adjusted for the thicker bar to fit. Again I have the mounts but will I need shorter spacers? I'm not sure what the part is called that it bolts to. I'm referring to the bar with bushings on both ends. Someone please help.
