megaladon6 said:to correct a point here, synthetic is not thinner than conventional oil. syn will tend to get by the rings more however. this is because it sticks to the walls better than conventional. also, it "slides" on itself better which means that more can be left on the walls. this is also why it works better than conventional. obviously this means that more can be left in the cylinder and burn.
as to it burning clearer? it's possible, but not by enough to make a difference. as stated i'd just go to a slightly heavier oil.
Syn oil is thinner.
Dino oils base varies in molecule size where syn's base does not, its consistent.
Think of dino oils like blood and has a clotting ability and syn's don't. This is why if a engine might have had a leak or worn seals syn oils will bring it out to appear where dino oils won't.
In any event, both oils will burn and create a smoke and as mentioned the smoke might be of a different color because of the base of the oil. Both use pretty much the same additives, its just dino oils base will not suspend the additives for the same time period, thats why they say it breaks down faster.
Now if I was to pick a syn oil that mimicked dino oils but added durability length it would be Mobil one. I know, I have a better brand, we hear it all the time. But Mobil one holds patents and was the first out of the block to see that syn oils caused seals to shrink etc and added some other additives to make this clotting ability like dino oils, which those patents protect and will for a few more years. Those added additives can not be used due to patent protection in other syn's.
