please explaintlonz88442 said:U can do it yourself ....If needed I can guide u in the that I did mine
car has a 14 point cage mid-high 9's,Im going to check the latching arms as soon as my new one gets to the house to see how far the arms go into the socket and adjust to make the arms on the tops go in furtherinto the socket and then silicone both down.hopfully that will work88hurstolds said:Are you using regular or locking style T-tops?
You could just lock them but I suspect that the body is twisting so much that they are coming out of their sockets.
Is the rear seat braced and the frame boxed?
If you are looking for a permanent solution you could extend the locking arms so that they sit into the sockets further with round bar.
or
Hillbilly solution...run a motorcycle strap across the roof from window to window.
