When I ran a T5 in my old Malibu I used these.
Hedman 68310
They are long tube but do not interfere with the mechanical or hydraulic linkage.
Those might be the ones I have on my GP.....
Hedman 68310
https://www.summitracing.com/parts/ram-1509/overview/make/chevrolet
153 tooth 10.5" 1 piece rear seal
Ok so I have been busy and didn't get back to let everyone know how the headers worked. They are currently on the car and worked better after I modified them a little bit. I had to cut the collector right by the four tubes and bend it down so it was level. Then welded it back together and put my o2 sensor there also. They would have worked without cutting but I didn't like how close it was to the slave cylinder. It was all worth the headaches and five different sets of headers when I drive down the road grabbing gears!I have been looking at a bunch of different headers and those were the ones I thought may work. I was hoping pontiacgp had these ones and thank you to TURNA. I guess I will order a set of these and hope for the best! I will post back when I get them on if they fit. I have angle plugs as well and hope that won't interfere with the solution.
