Whatup? I have an efi'd 406 sbc with the small distributor, and external coil. The other day the my tach stopped working. I thought it was the tach, so I had a Sunpro sitting around, and I installed it. Same thing, It lights up, but no needle movement. I thought the wire might be cut or something, so I pulled a new wire from the tach to the gray connector white wire, and still nothing. The question I have is what sends the signal to the tach wire? Is it 12v or is a ground? Bad distributor? I have installed a new ign control module, coil, cap, rotor, wires, and plugs. Under the rotor, there is a little surface rust, but I don't think it is that bad too warrant a new distributor tho. Any help would be appreciated, I'm stumpped.
