Tall Valve Covers
SupremeSpeed
596
802
GA
Exactly how tall do I need the valve covers to fit properly with room for the rockers? They are Edelbrock Performer Heads for Olds, with roller rockers.
lilbowtie
3,460
3,965
Canton Mi
Probably hitting the poly locks - an Olds tall cover should take care of you or you can use a spacer.
-83MONTESS-
4,570
967
Bellevue, Ohio
My dad had a similiar issue with his Olds 455. He ended up with a cheap set of tall chrome covers off ebay. Fit and work like a charm. They are both baffled also.
dr78442
731
912
massapequa park NY
Not sure if you're running a small or big block Olds . I know tall valve covers will hit the factory A/C box if you're a BBO
24,221
That motor looks mean! Thanks for the information but the stock covers wont fit, they sit on top of the rocker arms.
No, you're probably hitting the baffles. I few dings with a hammer, and you should be good. Or, look at some of the Olds vendors for some rail spacers.
SupremeSpeed
596
802
GA
These are the ones suggested but I like the 2nd option best. Just don't want them too tall for clearance reasons. The first ones look cheap I'm my own opinion.
-83MONTESS-
4,570
967
Bellevue, Ohio
