TAPPING INTO FUSE BOX QUESTIONS
toyinhawaii
16
7
THE CIRCLED AREA ON THIS ATTACHED BLOCK ON THE FUSE BLOCK CONTAINS A HOBBS PN 1253637 BUZZER FOR THE SEAT BELT(THE 4 PRONG CONNECTER), I REMOVED THIS YEARS AGO, WHAT ARE THE OTHER SILVER PLUG WITH BLACK SQUARE AND THE WHITE SQUARE RELAY? IF THESES ARENT NEEDED THEN I WAS GOING TO REMOVE THE BLOCK BUT THEN WOULD HAVE TO DEAL WITH CUTTING THE WIRES,ETC. AND I DONT WANT TO DO THIS, BUT IF THOSE 2 PLUGS ARENT NEEDED CAN I REMOVE THEM AND CAN THE BLOCK BE REPUROSED FOR SOMETHING?
TO THE RIGHT OF THE FLASHER RELAY IS A PINK AND A RED WIRE,BOTH COMING FROM THE "batt" TAP. THESE ARE GOING TO MY CADDY POWER SEATS WITH A 30 AMP FUSE ON EACH(HOOKED UP TEMPORAILY). I NOW HAVE 2- 30 AMP RELAYS WITH A 10 GUAGE WIRE THAT I WANT TO HOOK UP TO THE "BATT" TAP BUT CANT FIND A PICO TAP W/ 10 GUAGE WIRE...ANY SOURCES FOR THIS? THOSE SPADE CONECTORS DONT HOLD UP WELL..KEEPS SLIDEING OUT
TO THE LEFT OF THE FLASHER IS A 12 GUAGE RED WIRE GOING TO MY AFTERMARKET POWER DOOR LOCKS UNIT, I INSTALLED THIS PICO TAP W/12 GUAGE WIRE, AND ITS GOOD NOW.
I ASLO HAVE A COBRA CAR ALARM THAT I AM HAVING TROUBLE FOLLOWING INSTALL. INSTRUCTIONS... I WOULD GUESS I CAN CONNECT THE + WIRES UP TO THE FUSE BOX "BATT TAP" TOO? I WILL ASK ABOUT THE ALARM AT A LATER DATE UNLESS SOME ONE CAN HELP NOW
ALL IN ALL, I WANT TO FABRICATE A BRACKET TO MOUNT THE 2- 30 AMP RELAYS FOR THE SEATS, MOUNT THE POWER DOOR LOCK UNIT TO IT AND MOUNT THE CAR ALARM UNIT(SMALL UNIT APPROX. 3" X 3'') AND THEN MOUNT THE BRACKET TO THE ATTACHED BLOCK WHERE YOU SEE THE TOP AND BOTTOM MOUNT HOLES. I AM THINKING THIS IS TOO MUCH CRAP TO MOUNT IN THAT AREA . WHERE DO YOU ALL MOUNT STUFF LIKE THIS ? CURRENTLY I HAVE THE TEMP 30 AMP FUSES AND THE DOOR LOCK UNIT STUCK UNDER THE CARPET BELOW THE FUSE BOX
THANKS FOR ALL THE HELP!
toyinhawaii
16
7
