Temp gauge tweaked
SoFloG
1,107
1,258
South Florida
So, the other night took the car out and after beating on it decided to get some food. Backed in to the restaurant and get out and heard and watched the lower radiator hose let loose. Temp was at about 200 and I spent the previous day on the road for an hour in traffic... never went above 210. I also never tightened the hose clamp from weeks earlier. Anyways, I decided to drive it home about a mile away after tightening the hose and the gauge went all the way back to the stop pin. It wasn't that hot but I think the steam got to the temp sender which is on top of the intake manifold. Hose tight filled back up with water ran it and now it's running around 230 instead of 190.
Long story short the Gauge is now reading zero around 140, even dipped in ice water. Is there any way to calibrate or is it just a cheap pos and I should throw another gauge in?
Ernest
745
1,012
Texas
Theres isnt any recalibration that can be done that im aware of, so the water temp gauge is probably hosed..... get another, and if you care about your engine, go with an AUTO METER gauge set.
Reactions: 4 users
Sweet_Johnny
Has A Face For Radio
667
1,217
Wichita, Kansas
Equus makes decent gauges at an affordable price. Also, make the jump to electric gauges if you can- it's real nice not having to run the lines for the water/oil and leaves a much cleaner appearance.
Ernest
745
1,012
Texas
The Equus gauges arent too bad... im using a manual oil pressure and electric water temp gauges, came with the car when i got it, no clue how long they have been installed.
A good 6months ago, i had to replace the oil pressure gauge, the needle was sticking where it wanted, so it wasnt able to show the correct oil pressure with engine running, but when im ready to redo my entire gauge set, im definately going with AUTO METER.
