Th200-4r TV Cable Bracket
84GP455
779
96
Methuen Ma.
I need some help as to which tv bracket to use for my th2004-r transmission with my edelbrock carb and manifold setup for my Pontiac. I have tried 3 so far and none of them work correctly, I tried the stupid universal one but it didn't line up correctly. I am currently using the one from TCI-376700 and the TCI-376710 corrector kit. The problem seems to be the cable is too short, I have it adjusted all the way out and it doesn't want to shift into the next gear unless I release the gas pedal and step on it again, then it goes into 2nd gear. I need someone who has a similar setup like mine to tell me what bracket they are using and what cable. This bracket that I am using now was hitting my manifold so I had to get a 1 inch carb spacer to lift it up to keep it from hitting the manifold. This is very frustrating as there are many different setups and cable lengths from different cars, I am pretty close now I just need the cable to be a little bit longer. The transmission and cable came from a 87 GN any advice would be much appreciated.
G-Body_Vet
2,937
81
48
I'm watching this thread too....may even do some digging to see if I can find an answer because I'll be facing the same dilemma when the time comes. I'm going to be using a Q-jet and performer intake on my 455 though.
techg8
475
342
"I'm going to be using a Q-jet and performer intake on my 455 though"
TCI 376700 will work with the Quadrajet setup FYI, I have used it for that.
Sorry to the OP I dont have info on what will work right on an Edelbrock.
84GP455
779
96
Methuen Ma.
He's right, the TCI 376700 didn't work for my Edelbrock WTF!!! Doesn't someone make a bracket for an Edelbrock with performer manifold for the TH200-4r? There must be some Pontiac guru out there who has done this swap before>>>??? Anyone??
8,827
7,783
You may need a longer cable, plain and simple. It could be the Edelbrock linkage is further foward, requiring a longer cable. You would think Edelbrock would offer multiple bracket options for cables, especially for the 700R4 or 2004R.
G-Body_Vet
2,937
81
48
I think most of the Poncho crowd prefers Q-jets!
85GPLef41
2,210
159
Colorado
i used edelbrock 8031 throttle bracket BUT i had a SBC... :| did you look into bowtieoverdrive's kit? http://www.tvmadeez.com/ and i agree with gbody vet i would probably go with a modded q-jet :mrgreen:
956Neto
23
Weslaco TX
Dam bro! I had the same dam problem and got sick and tired of it... went thru 6 transmissions until I decided to switch to a TH400.... now my car shifts way better but minus the O/D part. But yeah if ure into that transmission working, buy the proper bravket u need and be sure to adjust it right if not ure gonna burn out the transmission... Good luck with that!
84GP455
779
96
Methuen Ma.
Yes It's very frustrating to say the least! And I am not switching to a q-jet, this Edelbrock runs way better than any q-jet I've had! It is very crucial to get the proper setup for the tv cable/bracket it has to be the right geometry or like you say it will burn out your transmission fast. I am not giving up this transmission either its a 87 Grand National BRF code and it's way more responsive than the TH400 that I've been running for 25 plus years! i'm not going back to a three speed I like the OD too much.
84GP455
779
96
Methuen Ma.
I thought that the cable only came in one length>?? Can someone verify this? I've only seen them sold as a universal cable.
