I'm almost done with the rebuild on my TH350 and I've run into a problem. While trying to replace the 2-3 Accumulator Piston in the valve body it broke. GM used to use an aluminum piston and then switched to a plastic one. Mine is the plastic kind.
I called the local transmission shop to see if they have one and I'm waiting on them to get back with me. I can order one if I have to buy that'll put me even further behind.
Does anyone know if another GM transmission uses the same Accumulator Piston? I can probably go dig through the transmission cores at my old job and get one if I knew which transmission to look in. This is the accumulator in the valve body.
