All,
I have research and it seems that a 200 crossmember (maybe it is just the 200R) can be reused to support the 350. Apparently, it can be drilled and relocated, although when I try to locate pics of the mod the frame of later g-bodies that had the 350 the frame seem to be different in that area.
Am I able to relocate the TH200 crossmember?
Am I able to use an aftermarket dump hump crossmember? Like the Jegster 41050 or something else?
Thank you.
Boydness
Thank you.
Boydness
