I know "the internet says" 350C is junk, but why?
Supposedly the input shaft is weaker. Smaller diameter, IIRC, for the lockup apparatus?
Sounds like you should find another transmission builder, a good one can convert the TH350C to a regular Th350. I have a built TH350C and I didn't use the lock up function. The main difference you'll have to deal with is converter selection and higher converter cost, I have an acc boss hog 2800-3200 and it cost about 450 bucks. There's not a huge selection. Also if you crack the bellhousing like I did you can't use a jw ultrabell because the converter depth is different so you'll be stuck finding a different case. But they can be built to handle abuse if you go to a reputable builder
