black_aerocoupe
- Apr 12, 2012
- 104
- 28
It is not often a build gets as much serviceability and reliability forethought as is needed. Good work. Widely available stock type parts are sometimes the best answer.
Is that the BS plastic Camaro slave cylinder? Those things didn't work right in Camaros. Heat prone and crack prone. The after market started beefing up their Chevy brackets by using almost a 1/2 thick plate. I've seen how the 1/4 inch Chevy bracket can flex right where it holds the cylinder. I was gonna do mine like that, but iI saw the potential flex when I made the paper template. The bottom hole in my bracket gives the bracket an extra bracing from another angle. No flex so far and I have a stage 3 clutch plate and a stage 2 disc. (Supposed to be good to 500hp. It feels like it)
If it dose flex, I'll go with upping the thickness also.
T
Interesting, hope it is more trouble free. What headers are you using?Danggit, they don't make the Elite for Oldsmobile engines. Oh well, I did look at the headers I want to use and after they get customized, they should clear the slave.
Headman 58160 block hugger shortie. I'm going to weld 3in ball ends to them. That mod will allow them clearance for the Gbody. (There is no room for the 3 bolt flange that come with it. yet it clears all the older 60s and 70s Oldsmobiles.)Interesting, hope it is more trouble free. What headers are you using?
those 2 bolt style flanges are much stronger than the 3 bolt flanges that are used on the headers. I have to cut my 3 bolt flanges off to put on thicker flanges so they don't fold due to heat and loosen up the collectorHeadman 59160 block hugger shortie. I'm going to weld 3in ball ends to them. That mod will allow them clearance for the Gbody. (There is no room for the 3 bolt flange that come with it. yet it clears all the older 60s and 70s Oldsmobiles.) View attachment 98204 View attachment 98205
Driving impression. The Howe unit gave me a very heavy pedal feel, but it was almost instant clutch release. The mechanical advantage the clutch fork gives lightened my pedal feel greatly. It feels like the last F-body I drove. (A 96 Z28 Camaro LT1 6spd )
I have to get used to it again.
T
I did, but it bent and I never fixed it because I never even came close to bottoming the master cylinder out. With the Howe the moment I pressed the pedal, the clutch was starting to disengage. It used about 25% of the full pedal travel.when you were using the Howe did you install a stop for the clutch pedal?
