BUILD THREAD “The Juggernaut”
There’s a big surprise…… Not! 😉
What’s not surprising Mike?
The fact that a resolution was found, the fact that I got back on it before I said I would, or that I will be sharing pictures of it?
Hahaha
Brilliant! I look forward to seeing the evidence 😀
Ask and you shall receive…
Coming up after this!
Super, sometimes even a magician like yourself needs help. Glad your friend could help.
Magician? Most times I feel like the sorcerer’s apprentice!
Hey RKTPWRD, I was going to suggest a garage visit with a bunch of adult beverages. Glad to hear you are once again good.
Randy
I would like that Randy, I will set something up with you. Not this weekend as I’m helping my stepdaughter move, but maybe the weekend after that!
Ok, so here’s what we did to correct the problem:
The vertical cut on the right in the picture above is the first relief cut that I had made separating the panel into the 2/3rds - 1/3rd configuration I referred to earlier. While this cutting and drilling out the spot welds along the pinch weld allowed the 2/3rds section to move and sit down properly, the 1/3rd section stayed VERY firmly put.
Now I know it looks like a patchwork quilt, or maybe something from Dr. Frankenstein’s workshop, but this was honestly the best and easiest solution to overcoming this obstacle. What we did was to make a second relief cut (on the left in the picture) from the pinch weld flange almost all the way up to the weatherstrip channel.
We stayed 3/4” away from the channel to preserve its integrity and shape, and left a tiny little bit of metal at the bottom by the pinch weld. Then we cut along the bottom of the weatherstrip channel back over to the original relief cut, still staying 3/4” away from it.
This allowed the piece to “fall” back into alignment with the rest of the body lines, with some minor trimming of course.
A little hammer and dolly work as we went along helped things immensely, and once we had things starting to align, we would place a tack weld to retain its position. We would check the fitment and alignment against my fabricated piece periodically as we went, just to make sure that nothing moved anywhere it shouldn’t, that we were still on track, and that my piece stayed level with the trunk lid.
Once we had the top three seams aligned and tacked together, we then concentrated on making a new pinch weld flange for the bottom. I bent up an 1 1/2” wide piece of sheetmetal on my metal brake, and then we notched it around the factory dimpled depressions, punched plug weld holes in it, and started tacking it all in as well.
So this is what it looks like currently. It has its structural integrity restored, but I’m a long ways from even having it fully welded in just yet. As Churchill once said “this isn’t the end, this isn’t even the beginning of the end, but it’s the end of the beginning”.
As you can see in these next two pictures, the spot weld flange behind the tank filler neck still needs quite a bit of attention:
Especially here, where I can fit my fingertips between the two layers.
It’s going to need quite a bit of hammer and dolly work in this area to bring the layers back tight together again.
Two more views, one from the passenger’s side, and one along the back to show that the flat area is still nice and straight:
It’s quite surprising actually, the whole thing, and especially the driver’s side actually physically looks more symmetrical and proper now than it ever did before.
Now I’m sure you’re thinking, “but why did you do it that way? Now there’s so much welding and bodywork to do to it.” Yes, the “correct” way would’ve been to drill out all the spot welds along the trunk gutters, quarter panels, trunk floor etc etc, remove it, square up the panel, and weld it back in straight, but honestly this accomplishes the exact same thing but without reinventing the wheel and creating a whole bunch more work for myself.
So anyways, there you have it. Lots of work still ahead of me just to get back to square one, but at least now I have a solution, and more importantly, a resolution.
D.
While it sucked, it's almost kind of refreshing to know that you're human. Especially now that you've moved past this ordeal.
Oh, I am very much human, despite all the praise everyone heaps upon me. I screw up all the time just like anyone else, trust me. I’m just very much a perfectionist and have a natural penchant for problem solving (especially when it comes to moving metal around) so it bugs me immensely when I come across something I can’t resolve immediately.
I’m very glad to have found a solution to this.
I’ve only had two nights this week to be able to work on it which is unusual for me, but good progress has been made each night.
The first night I worked on the flat center area of the pinch weld behind the tank filler neck. It required quite a bit of heavy duty hammer and dolly work to get the thicker metal of the trunk pan to move out to meet the tail panel, but I eventually got it.
No more big gap that I can stick my fingers into. The inside reveals the extent of the work:
I just realized in looking at that picture that I had a couple of porcupine quills sticking out of that one spot. Haha. Eh, I would’ve found them eventually.
Tonight I got a couple more hours in on it and welded up the vertical seam and the seam below the weatherstrip channel.
Knocking the welds down to nearly flush and then hammer and dollying the area worked nicely, and then I finish ground the surface.
Im leaving the surface profiled in 36 grit so it has a nice tooth for the body filler to stick to, this whole rear panel has been so extensively worked that it’s going to need it. It’s all highly visible when the trunk lid is open.
Unfortunately the next several days and my weekend are already spoken for, I won’t get another chance to work on it again until probably Monday night, but I’m very pleased with the progress already in such a short amount of time.
Rear tail panel surgery? What rear tail panel surgery? Frankenstein’s monster has been vanquished.
Also made a quick little patch to fill in the original taillight wiring harness grommet hole:
It’s easier to make a new hole afterwards in the desired location than it is to try and make something work with that oddly shaped hole. It may end up the same as the passenger’s side, we shall see.
Tomorrow we start fitting my fabricated filler panel back to it again and making the necessary additions and new top section for it.
Right the F on! It sure didn't take you long to put that one to bed.
Nope, a couple hours a night over 3 or 4 nights is all it really took. Given some time and the proper motivation, when I knuckle down I can really get some shjt accomplished.
Looks great. You’re taking one these poorly built cars and making it not only perfect, but symmetrical. The second part is probably harder.
learned when I was doing my sail panels. The left side seam was in about 1/8” and the right side was out an 1/8”. Resulted in more filler than I wanted but, it is what it is.
You’re not kidding Chris, it’s quite surprising just how NOT symmetrical these cars are. Especially once you start paying attention to the details and how the individual parts fit together. It’s a challenge to say the least. But that height difference in the tail panel that I just corrected is the worst I’ve seen yet. Fitting my fabricated piece to it sure illustrated that in a big hurry.
I’m not entirely out of the woods just yet, but I’m a helluva lot closer than when I started. I know there’s still going to be some tweaks and adjustments needed plus the material I now have to add back to my piece, but I have a pretty good feeling about it.
It might actually all work in my favour, provided I can get accurate measurements for the amount of material I need to add back in. Now that I have to add to it, I should be able to make those pieces with bends already incorporated to act as flanges to spot weld through to the tail panel. It’ll be a lot stronger (and a little easier) than trying to butt weld flanges onto the edges.
