Lambchop76 said:
mikester said:
So if you would have used a 5" back space on the rear would you still have to use the spacer ? And what brand wheels ?
I don't believe so. We test fitted the rims prior to mounting tires on them and the were flat on the hub and like a 1/16" off the frame. With the spacer I have like 3/8" between tire and frame
Didn't even need to roll the fender lips either. It's got 2" dropped spindles in The front so the tires are really close to the plastic inner fenders and do make contact with them often, but I figure it will only make contact for so long. I either will remove them or get used to it.
