i have a electric fan which is controlled by a relay that is switch from a thermostat sensor/ switch located on my manifold right by the thermostat housing.i was just wondering if the switch is mounted to close to the thermostat housing is it going throw off the switch from working right.my temp sensor for my gauge is located in the block.so when the temp switch reaches 185 the my fan should turn on because that is what the relay sensor/switch for the fan is.or does the fan relay sensor/switch doesn't see that temp because it's mounted next to close to the thermostat housing.
