So I installed them this afternoon. If you still have the choke, do it off the car. My fuel lines are long enough I can pull the carb on and place it on the cowl in front of the battery to work on. Took about 15 minutes total from start to finish. Tested on the fender squirting into an oil pan, then bolted it back on.
The secondary jets have an OK pattern, I'm not that happy with the primary - most of the spray is right (onto the plate and down), but some goes straight out from the jet in a fine mist - I figured that couldn't hurt so I bolted it back on.
The initial throttle opening stumble is still there, but when it catches after the stumble it seems stronger. I did a few driveway clutch releases and it seemed a little stronger off idle. My kid came out and played with the car and he said is what a LOT better. I don't know if I'll go that far until I drive it a little.
The front end is tore apart again so that may be a few days.
