If you go to jegs, or summit, you'll find carb mounted brackets, that are carb and trans specific. The transmission shop lined us out on this one. Jegs #555-157313 It actually gets in the way of the vacuum port on the back. I sawed off the far side of the bracket to clear for brakes. The way we made it work is, 1 bolt in 1 hole, and a 5/16 dowel pin/sawed off bolt segment in the one next to it. Without the pin, it moves. By the way, my son says the Holley with it's bracket worked better. 555-157310 This is for a 700/200r4 and a Holley. Good Luck.
