Might be showing some newbie stripes with this one...
I am working on the 327 swap / manual conversion again after a week in Nova Scotia visiting family (there is a build thread: https://gbodyforum.com/threads/nostalgia-lemans-327-muncie-swap.82287/)
This afternoon I installed pilot bushing / flywheel / clutch disk / pressure plate on the 327.
I was then mocking up the bellhousing / clutch fork / throwout bearing installation without the transmission so i could see how things fit together.
What I found was about a 1/2 gap between T/O bearing and the pressure plate springs, when the clutch fork is seated properly in the bell housing ball stud.
the throwout bearing will only engage in this case on an angle with the pressure plate spring (i.e. T/O bearing face will not be flush with the pressure plate springs)
I haven't tried installing T/O bearing on transmission first yet, but something looks a bit off to me...
Thanks in advance for any thoughts.
Colin
Colin
