I have Dave's (Dave Ray) Small Body HEI dizzy on my SBC. Mech spring set blue/ silver. Has Crane 9960-1 adjustable vac. Dave recommended initial at +12, vac on at 22-24 and full mech (vac off) at 36. Got the 12-23 at 700 RPM no problem. My question is with full mechanical (vac plugged). I hit +36 about 2500 RPM but it keeps climbing leveling off about +44 at 3000+ RPM. Just put in new engine and builder wants total timing in 32-36. Backing full mech down to 36 would drop initial to 4?! I'm brand new to timing so I may not grasp this fully. Any advice is welcome as I don't want to screw up this new performance SBC. BTW has MSD ignition so can't use modern dial type timing lights. I used old school timing light without advance dial. MSD tech says this only way to time their ignition systems. Reason - Multiple spark at low and extended spark at high RPM confuses the modern lights.
Other forums indicate Dave has instruction to alter mech advance however when I contacted him (long story short) and asked for more information to help me understand his recommendations he basically accused me of challenging his authority and cut me off. Seems according to him Crane instructions to do this are wrong so I am at a loss to know whether or if I should try to modify the max mechanical advance to achieve Dave's recommended 12-36 off vac initial & full advance.
