get a timing light connect it tho the car
make sure car is running and at normal running temp.
verify check engine light is not on
disconnect distributors four wire electrical connector
(check engine light will come on)
set timing to specfication (pretty sure mine says 15 degees)
reconnect electrical connector.
make sure car is running and at normal rumming temp.
verify check engine lightis not on
