Why TF is it impossible to find a tire gauge that isn't a total piece of crap? Can someone recommend one that actually reads correct and consistent? I've spent $2 I've spent $9, I've gotten ones that have almost unusable ranges for auto tires (up into the high 100's) making reading it difficult at best. I've had ones that won't read consistent to save a life, with a good 15lb difference in repeated readings. I can't seem to find any that you might consider "good" aka a higher price tag at the auto-barn outlet or bigbox stores....
Now I've got one that has a "dead spot" on the slider between 30-40 lbs, basically rendering it a dud. 30 and below? no problem? over 30#? it'll only show 30 until it actually gets around 40!
I'll spend a bit of $$ on one that doesn't suck and will last a while. Not a fan of the dial-type because they take up space and you have to not break them, but if that's what I need to get then fine.
anyone? just PO's when you're trying to put air in your tire and its like 30. 30. 30. 42!!! Woooo! 30. 30. 41! 😡😡😡😡😡
