Pedals are custom made and welded. American powertrain makes G Body pedals now but each pedal is the size of a parking brake pedal. So we cut off the pads and welded on larger plates from a G Body malibu and welded them on to make for more surface area. as far as the clutch, it is a Kevlar clutch. The set up is Hydraulic from american powertrain. The bell housing is a quick time set up also from american powertrain and the flywheel is billet steel from McLeod. The entire set up was a LOT of custom fab and testing and measuring and testing and measuring and more testing and measuring! But I couldn't be happier witht the final result. We are actually working with a few vendors to use our findings to make a G Body swap out set up for this application now that we have worked through a lot of the kinks.
Oh yeah, cross member is a G Force, but even that had to be modified a bit when we swapped the AOD for the tremec
