To computer or not to computer
Metzger82
102
95
NW Ohio
I know im beating a dead horse (sorry PETA people) but i need some help. So some reason every time I go looking through the Pantheon of gbody information on this site I can't seem to find a direct or somewhat agreed upon answer on whether or not the factory computer is still needed after an engine swap in a G-Body Oldsmobile Cutlass. I ask because I'm swapping out my tired Olds 260/TH350C for a Olds 350/TH350 that I've built. I'm also doing away with the air conditioning and installing a factory heater only box.
Streetbu
Know it all, that doesn't
3,734
11,581
Central NY
Depends on what carb and ignition you're using. If stock factory parts, then yes. If other, no.
Reactions: 6 users
Built6spdMCSS
5,803
9,715
Florida Beach
Not sure how a "direct answer" hasn't been seen since this subject has been beaten into the ground from the few things I've seen over the years, and I don't pay attention to anything Small Block given I LS Swap everything..
As mentioned above, if you are keeping the exact factory Computer controlled stuff, then answer is obvious.
If not, then also, answer is obvious.
69hurstolds
8,198
17,600
Apparently not.
Metzger82
102
95
NW Ohio
Well I guess that answers my question. I was just curious after reading many posts the last few days because it seems to be that everyone has a differing opinion when it comes to how the HVAC systems on the Oldsmobiles operate. I don't remember how long ago the post was but I remember something from CloneTIE that said that every system was a bit different by division in General Motors and that Oldsmobiles may use the computer more for operation in the HVAC. Obviously I'm asking to learn but hey whatever.
Built6spdMCSS
5,803
9,715
Florida Beach
Heat only is very simple with no computer involvement, so there's that.
pagrunt
9,167
15,346
Elderton, Pa
On our cars regardless of the engine, the computer won't be needed to have the HVAC function. Some later ones will have some interaction but for your 260 to 350 swap just refere to the earlier Olds powered Cutlass set up like the '78-'80 cars but I'd suggest setting up the wiring of an '80 as those are closer in set up to you '82. There are variances between the years with under hood function componets.
Metzger82
102
95
NW Ohio
Thank you, its much appreciated. That will be very helpful in getting this taken care of.
Clone TIE Pilot
3,861
2,612
Galaxy far far away
I am not as familiar with Olds CCC systems but I think that in 86+ Cutlasses the ECM controls the compressor instead of a pressure switch.
565bbchevy
9,614
12,683
Michigan
My 86' Regal came with a 307 and nothing on the computer side controls my AC
