ok man that topic could go more ways then one. so we are talking engines here guys
so here we go. if you saw my rear end thread you might have noticed that i got a 4 bolt virgin block for $20. so i would like to go back with this build with this block instead of my .060 over 2 bolt block.
s0 that means ill be boring it out .030 over. and i will need new pistons regardless since you cant shove a .060 piston in the hole haha. so my question here is should i stroke this motor or keep it as a 355?
i plan on using the same cam since it is what i had the heads set up for.
Brand:Howards Cams
Manufacturer's Part Number:110265-12
Part Type:Camshafts
Product Line:Howards Cams Max Torque Retrofit Hydraulic Roller Camshafts
Summit Racing Part Number:HRS-110265-12
Cam Style:Hydraulic roller tappet
Basic Operating RPM Range:2,400-5,800
Intake Duration at 050 inch Lift:234
Exhaust Duration at 050 inch Lift:242
Duration at 050 inch Lift:234 int./242 exh.
Advertised Intake Duration:294
Advertised Exhaust Duration:302
Advertised Duration:294 int./302 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.533 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.548 in.
Valve Lift with Factory Rocker Arm Ratio:0.533 int./0.548 exh.
Lobe Separation (degrees):112
Camshaft Gear Attachment:3-bolt
Computer-Controlled Compatible:No
Valve Springs Required:Yes
Camshaft Manufacturers Description:Rough idle, Hot Street and bracket racing. 10.0:1 and up compression ratio advised. 2,800+ stall.
Quantity:Sold individually.
Notes:Retrofit roller cam for engines that did not originally come with a roller cam
heads are profiler aluminum 195cc w/64 cc chambers. they were setup for the cam above, pocket ported, bowls blended etc by chad speier of speier racing heads. the intake is a perforer rpm the was mildy ported, plenum divider milled down, and gasket matched to a 1206.
so should i go the extra effort and stroke it out or just build a 355?
Brand:Howards Cams
Part Type:Camshafts
