it was soo cool there was condensation on the windows. and there was only 7-10 cars running since it was a test and tune, it was a sanctioned event for money so everyone quit early. i got there late (starts at 6pm, i got there at 8) and it ends at 11.
^^just some backround on the situation.
cars setup-
'97 vrotec 350 with HOT CAM KIT, edelbrock rpm intake, holley 750 vac. secondary carb, MSD digital 6 and pro billet distributor, 2.02 intake and stock exhaust valves, serpentine belt setup from same '97 truck, flowtech headers, homemade 2 1/2" exhaust with two chamber 40 series mufflers, GM performance parts 16lb nodular iron flywheel, stock replacement DYNA-PAC clutch, T-10, 8.5 3.73 posi axle from un known year coil spring car, air bag in right spring, no hop bars, traction action bars, boxed control arms, frame, and lower control arm mounts, sportsman pro's, COMPETITION ENGINEERING 90/10's in the front, cheater plate setup with 100hp shot jets, holley red fuel pump.
first run without nitrous 13.01 @ 98.XX MPH
best run with 100 shot of nitrous, 12.23 @ 121MPH.
the two previous times a had it at the track without nitrous, MSD and distributor, 8.5 rear, and before the frame and control arm mounts were reinforced i broke a drivers side axle. both times, and i cracked the frame in between the upper and lower control arm mounts.
the best time then was 13.7 and i had to launch at 1500rpm or less cause thats when it pops the 7.5 axles.
cars setup-
