Torque converter
Dylan88
164
23
36
Needing opinions on what rpm stall to get for my car 1981 malibu
Th350
Cam is 227/234 .600"/.600" 114 LSA 111 ICL
373 gearing
Dynoed 400tq and 375hp
5.3lm7
Was thinking a 3400 3600
I got a 2800 in it now but seems too low
Was there a recommendation on the cam card? How much does the car weigh? What's the car's purpose? Why does the current converter disappoint you?
Kind of surges at idle in gear from big cam. Can't remember recommendation
Do you happen to know how much vacuum it's pulling when this happens? And is the 227/224 the advertised duration or @ 0.050?
The car's use and your driving style are also factors when choosing a converter, as is the power to weight ratio. A light car doesn't need as high of a stall, and going with one over 3k can be problematic in stop & go traffic. They're great on the freeway though.
Can't remember weight . Maybe around 3200lb? Yeah I use it daily not much highway driving, just the 2800 seems to low so looking for the sweet spot
Reactions: Griffin84ss
Yank, Circle D, and Pro Torque are all good converter companies to deal with. They make quality products and stand behind them. Be sure to discuss STR (stall/torque ratio) with them (or whoever) to guarantee you get a unit that performs the way you like. You can have a 4k stall converter that's good in stop/go traffic but flashes to 4k if you have a high STR. The trade off is the converter loosens up in the upper RPMs. No bueno for high RPM cruising, but these work very well with 6 speed autos. A low STR will get you a sloppy loose converter down low but it'll slip less up high- this may mean keeping the lead in a race or just cooler converter and fluid temps on the highway. It also cures surging through the brakes. A car driven mostly in town may be better suited to a converter with a high STR to help it get up and go without having to mash the pedal.
In other words, it's possible that your stall is perfect but the STR is off. However, LS engines do love to rev and most F Body guys are running a Yank in the neighborhood of 3500-4000, with an STR in the low 2s.
Great advice above from others...
I would only add...If you plan on doing a fair amount of highway cruising at 50-55+ mph, and you're not building solely for drag racing I would highly recommend you consider going with a lockup converter if your TH350 trans supports it.
I don't remember which years, or applications had them but you will improve mileage. More importantly you will see lower overall trans fluid temps with lockup, and if you're using the OEM in radiator trans cooler any extra heat from the trans fluid will transfer into your coolant temp as well. Any kind of drag and drive events too, lockup torque converters are your friend imho.
Just something to think about, if your TH350 doesn't have the provisions for lockup then disregard this advice.
Reactions: Sweet_Johnny
