TPS adjust?
GermanDude
8
Germany, Brandenburg
hey guys,
I think i have a problem with my TPS.
I have 3,5V by closed throttle and 4,8V with fully opend.
I try to adjust the voltage by turning the small screw in the pic but nothing happens...
What is wrong here?
thx
Can't tell from pick, but that looks like a screw in style plug over the TPS adjustment location so you're basically turning the plug and not the TPS adjustment screw. I'm sure that's not the case ( as I assume that would be obvious to you if that were the case ) but that's what it looks like in the pic!
Other most likely reason is it's just a bad TPS.
Looks like the carb was rebuilt not to long ago. The plunger on the TPS could be interfering with the gasket and not extending all the way out.
Reactions: fleming442
