track ready
Wingnut
10
4
49
Pa
88 Monte SS pump gas sbc 421 350th trans 3:90 gears 3212# no driver off to the track Sunday to see if different set up works. Previous best run 11.15 @ 122 mph running pump gas through the exhaust. Freshened heads and bottom end changed cam and converter
with that 122 mph , it should be in the 10's
Good Luck
Reactions: pontiacgp
What is your 60’ time now? I agree at 122 you have the power to be in the 10’s. When I had my 433 in the chevelle I was going 11.20’s at 118. 122 got me into the 10.80-10.90 range.
If you run the numbers he is pretty much spot on. You have to remember he is probably over 3400# w/ driver. He is making HP.
Hopefully get break into the 10s the cam and converter change seems to have made pretty big difference I'll check 60ft times when I get home spun a little after lunch made some changes
Ok the 60’ is definitely soft, so hopefully the converter wakes it up there. For your et, 1.50 is a good number to shoot for. What rpm is it crossing at, there may be more room for gear to help it leave.
Reactions: fleming442
