I guess what I am used to is how dsmlink does it. The ecu looks at knock retard and allows you to program when the light turns on based on the number of degrees of retard. Most run this around 5 degrees, I go for 2. I’ve done this on 91 pump and E and had terrific results. Even with stock rods & cast pistons with 25 psi on E or 15-18 psi on 91 pump.Terminator monitors knock very well. The issue is that the knock sensor is not tuneable, or I should say the terminator will not allow for tuning of the knock sensor. The factory knock sensor are tuned for a stock motor, so if you do much of anything to the motor other than run it in stock form, the knock sensor is somewhat useless. This includes cam, solid motor mounts, spinning it 7500rpms, etc.
And Northernregal is spot on, by the time your sensor registers knock it's too late. I've used tunable knock sensors and they're pretty neat, but roller rockers, big cams and lots of rpm's are demanding on those as well.
If you want to monitor something worthwhile, then monitor coolant system pressure. I'm yet to do it, but it seems to be that prior to lifting a head coolant system pressure rise is noticeable and tunable.
Regarding the Terminator, be advised it has only 4 inputs and 4 outputs available. This is fine for many builds, but I'm currently down to one open input and all of my outs are used up. And this is after having to repurpose the fan output - I put the fan on a thermal switch.
now I will say this will be first time messing around with a boosted V8. Also my first time with a supercharger. I’d prefer a turbo set up, but I’d like to eliminate some of the complexities in favor of reliability for some road trips.
I guess I had imagined things being similar (boost level-wise) when it comes to knock threshold but I also haven’t had 7 other cylinders pushing a piston up either
