Yes. Once I got to 8-9 quarts I was constantly checking it while it was idling.Did you check the fluid on the dipstick for over-full?
No fluid leaking from the converter or the pump seal. Everything above the pan gasket is nice and dry.Hopefully you seated the converter all the way. If not, it didn't connect to the front pump.
Well, if it's dry all over, including the front behind the converter, it narrows it down to the pan gasket, or the tailshaft seal.
Wouldn't leakNo fluid leaking from the converter or the pump seal. Everything above the pan gasket is nice and dry.
