trans problem
84cutspreme
1,163
158
I think it is a tv cable issue...when I am cruising at 55mph and step on it (pedal to the floor) it stays in OD for a few and around 60mph it will drop back into 3rd and get up and go. Is this a tv cable issue? I am guessing I need to tighten the adjustment, but I set it the way they tell you to where during moderate acceleration 1-2 shift (10-15mph), 2-3 (20-30mph), and overdrive at 40-45mph. What do you guys think?
I've always set them by pushing in and holding the adjuster button, pushing the cable all the way in, release, then hit the pedal to full throttle and it will self adjust itself.
I tried doing it that way and for some reason it comes way out and is real loose. I wish it was that simple
yup
