So i finally get my car running and on the road, and another problem comes up
While driving around with some buddies, we noticed when it shifts from 2nd to 3rd, the car wouldn't accelerate in 3rd until i let off the throttle and it would catch. So we checked the fluid, and apparently I didn't seal the pan well enough, and had lost quite a bit of fluid. (I changed the fluid and filter back when I still had the 3.8) So we topped it off and there was still no difference. It slips mostly in the transition from 2nd to 3rd, but shifts normally the majority of the time from first to second. i tried changing the vac. line from the carb to the manifold, but still no difference. Any ideas on what to do?
Also i thought it was wierd that my speedometer is off a good 15 mph, and the needle jumps around a lot.
I have a new non-cruise control speedo cable and a bottle of lucas transmission fix. hopefully that will solve my problems. Could it be the vacuum modulator?
