transmission help
Thanks I just started working on the trans, should I just order one from advance or should I get it from summit ,jegs. I'm stuck which one should I but any suggestions?
I only use it for a daily driver but I don't just want junk.
Not positive but I would assume that a parts house like Advance will only offer stock-style remanufactured converters. Going to Summit or Jegs provides the opportunity to pick up a brand name converter that offers improvements like hardened hubs, better bearings and furnace brazed fins. You can also pick up a mild stall speed increase like 500 rpm over stock for better bottom end acceleration. Call the tech line at Summit or Jegs or even the converter manufacturers directly for advice.
