I have the stock transmission in my car it is a th350c, ive been looking at stall converters and am curious if I need to get a lock up one or if i can just get a regular th350 stall converter
Oldsmoletick said:The th350c has an extra "stub" sticking out of the input shaft, if it has been removed, the regular th350 converter can be used, however you lose the lock up. The stall speed will vary depending on how much torque your engine produces, the more it puts out, the higher your stall speed will be (that's why it is a range 2500-3000). Rear end gears also play a factor in this, for instance, my car with 2.41 gears with a 2100 stall, used to kick in at about 1700rpm, when I put the 3.73's in it jumped up to the advertised stall speed (round about). Another thing with this, are you doing a brake stand when you check, or are you just taking off? Like was said previously, if that stub has not been removed, the regular th350 converter physically will not fit on properly, not engage the front pump, and by chance if you can actually bolt your trans to your engine, you car will not move. Check over what you have carefully, you may have bought a 350c converter, or someone may have lobbed off the end of your input shaft.
